C6 Corsa axleback 06 vette
Tim C.
Regular
You're 5 C6 You're a Regular
Corvette 2006 Coupe
My exhaust system is 2.5 in. The Corsa I want to buy is 3.0 in. Can I buy an adaptor to increase to 3.0 in
There are 2.5"-3" adaptor like this that you can weld on or attach with band clamps similar to the OEM clamps between the axle pipe and mid pipe, but the problem will be space, as the axle pipes are the exact length needed to go between the mufflers and the mid pipe. If you're having a muffler shop install it anyhow, they should probably just be able to cut off the appropriate amount from the axle pipes then weld or clamp on a 2.5"-3" adaptor.
Thks
Should not have an effect as you are past any sensors in the exhaust portion of the system. I swapped out my OEM exhaust on my 2005 with a later NPP Z-06 system that had the adapter welded on. It was as esy as drop the old and install the new. No other changes needed. I did have to put in the Mild-to-Wild lines and controls but no computer mods needed.
Thanks so much
