My exhaust system is 2.5 in. The Corsa I want to buy is 3.0 in. Can I buy an adaptor to increase to 3.0 in
ThksThere are 2.5"-3" adaptor like this that you can weld on or attach with band clamps similar to the OEM clamps between the axle pipe and mid pipe, but the problem will be space, as the axle pipes are the exact length needed to go between the mufflers and the mid pipe. If you're having a muffler shop install it anyhow, they should probably just be able to cut off the appropriate amount from the axle pipes then weld or clamp on a 2.5"-3" adaptor.
Does the increase in the pipe to 3" affect the air flow thru the exhaust since mine is 2.5 "? or affect any of the computers?Thks
Thanks so muchShould not have an effect as you are past any sensors in the exhaust portion of the system. I swapped out my OEM exhaust on my 2005 with a later NPP Z-06 system that had the adapter welded on. It was as esy as drop the old and install the new. No other changes needed. I did have to put in the Mild-to-Wild lines and controls but no computer mods needed.
Yes fully understandNo problem, just to be clear though the pipes had to be cut to account for the length of the adapter.
