Transmission Fasteners Improperly Torqued. Solution: GM would replace your DCT.
the curse of the C8 Continues
Does that say , they will replace the transmission! The whole transmission?! Not just the fasteners !!!Transmission Fasteners Improperly Torqued. Solution: GM would replace your DCT.
No, it’s will be limited number of carsIs this going to be another "we don't know which ones are bad, so we'll inconvenience everyone, just in case" issue?
Wow. Just wow.
That’s correctDoes that say , they will replace the transmission! The whole transmission?! Not just the fasteners !!!
Assuming all customers with affected Vin's will be notified?? Another recall?? Or what the easiest way to see if your car falls into this range?Transmission Fasteners Improperly Torqued. Solution: GM would replace your DCT.
Never assume anything with automobiles.Assuming all customers with affected Vin's will be notified?? Another recall?? Or what the easiest way to see if your car falls into this range?
No, your car is way too old for this issue, this has to do with updated DCT that was put into late 2023-2024 carsI will be surprised, if I have this problem because my C8 was moved to the inspection bay, before being shipped out, so if that does not help, what is the point of having an inspection bay!
Add your vin to the end of this link to see all recalls on your car.Assuming all customers with affected Vin's will be notified?? Another recall?? Or what the easiest way to see if your car falls into this range?
https://experience.gm.ca/en/ownercenter/recalls?vin=
But it will be as good as new when you finally get it. I hope it’s soon. You do have to wonder about the 5 month delay though, shouldn’t take even GM that long to fix anything. The whole car is built in a day or two. They should be including an extended warranty for free because of the huge inconvenience. Or at least a kiss….sounds like this happened to my car. It sat in Michigan for about 5 months
I got my car January 30th 2023. So it is too old for this recall!No, your car is way too old for this issue, this has to do with updated DCT that was put into late 2023-2024 cars
After some back and forth we have come up with some compensation for the delays. hoping to get it Friday but who really knows.But it will be as good as new when you finally get it. I hope it’s soon. You do have to wonder about the 5 month delay though, shouldn’t take even GM that long to fix anything. The whole car is built in a day or two. They should be including an extended warranty for free because of the huge inconvenience. Or at least a kiss….
Do you know the build date on it? Was it in July 2023?sounds like this happened to my car. It sat in Michigan for about 5 months
Built sept 6Do you know the build date on it? Was it in July 2023?
Thanks. Food for thought.Built sept 6
