Question What is this rubber piece?
Cavu
2019 Coupe M7
I found this piece of black ribbed rubber loose in the aluminum pan 1 foot ahead of the drivers rear wheel. It was about to fall out of the 6” opening in the pan. It is 1.5” x 1.25 x .4”
Any idea what it does or where it’s supposed to be to located? Thanks
Just a guess but perhaps a vibration damper of some kind. Or a jack pad …….?
I agree it is probably some sort of anti vibration piece. It was on the top side of the aluminum pan so not a jack pad. No sign of a sticky back unless it has worn off. Likely something to stop the pan from vibrating. But where?
Maybe something here . And a link to the page it came from which has footnotes and links .
For a detailed C7 Corvette parts exploded catalog, here are some top resources providing comprehensive exploded views and parts listings for the 2014-2019 C7 Corvette generation:
• Corvette Central offers free downloadable digital catalogs that include exploded parts diagrams for all major assemblies, including suspension, drivetrain, interior, and exterior parts.
• Chevy Parts Pros and Keen Parts supply extensive parts catalogs with exploded views for the C7 Corvette, which are useful for identifying OEM part numbers and assembly order.
• Corvette Pacifica is a large Corvette parts and accessories store that carries OEM and aftermarket parts with detailed exploded diagrams online.
• Corvette Depot is another reputable Canadian supplier offering a wide range of Corvette parts and accessories.
If needed, links to catalogs and specific exploded diagrams for suspension, drivetrain, or other assemblies can be provided from these sources to facilitate part location and ordering
Thanks, I will have a look
"Corvette Depot is another reputable Canadian supplier"
Must have been AI that told you that. Most members here wouldn't have....
Yes .You have to read between the lines with information from AI search for sure. The link at the bottom of my post shows that it’s from an AI search engine. I’m not personally familiar with Corvette Depo so can’t really comment on them . Good to know though , thanks.
I found the part using a Google photo search, but still don’t know where it is located. MSRP. $65.51 LOL
GM Genuine Parts Fuel Tank Insulator​
GM Part # 95080135
GM Part # 95080135
I also did that and saw numerous similar parts but none identical. Good find. Maybe it will show up in one of the exploded views.
GM Part # 95080135
From Perplexity AI . For what it’s worth. Maybe it was added by someone in the past who was trying to cure a vibration or scraping etc . Interesting mystery….
The fuel tank insulator on the C7 Corvette is essentially the composite material construction of the fuel tank itself. This composite tank acts as an insulator and stores heat generated by the high-powered fuel pumps. There is no separate, distinct fuel tank insulator part; instead, the tank’s composite design inherently provides insulation .
Additionally, the fuel tank is mounted with support elements under the car, but specific “insulator pads” like those found in older models (e.g., anti-squeak pads in classic Corvettes) are not typically described for the C7. The composite construction takes care of insulating and heat management .
Thus, the location of the insulator is effectively the entire fuel tank structure itself on the C7 Corvette .
Lol . I see that your picture of the part is the first result on Google Image search now . And that no one over on the “ other unmentionable “ site knows anything about it either. Might be time to call in Inspector Clouseau …. ;)
Maybe we can stop quoting "AI" BS and stick to "learned knowledge"...
Yes, I even surprised myself with that post...
Thanks to AI "learned knowledge" will no longer exist in the future. AI will be answering our questions before we even ask them. To quote "The Fly" ....Be scared....Be very scared....
