small leak in passenger muffler near flange
Tim C.
Regular
You're 5 C6 You're a Regular
Corvette 2006 Coupe
Got spring oil change and they noticed very small leak in passenger muffler near flange....Any ideas..they said loosen flange, clean and apply muffler expoxy....??
can do it that way, but if want the easy way out can just clean the spot that is leaking which probably is a black stain with a steel wire brush and then just apply some muffler cement over it with your finger and let it cure and it should be fine. Can get the cement in a small tube at C-Tire.
thks so much
