I'll try that tomorrow...any special size?Try slipping a rubber O-ring on each of the two pins. This snugs up the top.
Thanks so much for the help.Not sure. Hole size the diameter of the pin.
The procedures in this video are good and I do them annually. The first time time the pins needed tightening but since then they've stayed tight. I don't use GM weatherstrip lubricant, just some silicone spray on a cloth.
Also try adding an o ring to the front contact pins as @Area Z51 noted. Lubricating and tightening reduced some of my noise then the extra o rings almost eliminated it.Cleaning the weatherstripping and applying a thin coat of silicone lube every year works for me. It reduces the friction noise but not completely. I never thought of tightening the contact-pins. Will do that next and see what happens. Thanks...great video!
Please do let us know the outcome after you are finished.The advice I've received has been incredible. I think I'll attack the problem today and take the car for a drive this week sometime if the weather improves. Thanks for the help
Where did you find the o-rings? I'm having a heck of a time locating some in that size.The o-rings I used were 1/2 OD x 1/4 ID. Definitely helped quite the roof down.
Can you share the item/link?I bought them from Amazon.
