Oil leaking 🙄
Hi.. l have oil leaking from this screw idont know what imust to do and what is that screw job and idont know what is that location name Even. Ichange already the oil gazget before 6 month Here is the picture And see what guys if they can help thanks.. c5 2003
long screw idont know how lfix that .. inever. See oil come out from screw like that..
I would wrap the threads near the top with plumbing Teflon tape and screw it back in. Teflon tape is good for up to 500 degrees Fahrenheit with very slow degradation up to 750 degrees.
I think that bolt just holds the bell housing to the motor. I was looking at the earlier pics and combined with what you sent I think that's all it is. I would take that bolt out and if you have a mirror look inside. If there is nothing but a tunnel then the oil is most likely coming from between the parts (engine and transmission) which would mean it could be a rear main seal. The one thing that looks weird is that vertical bolt on the bottom. It had fluid around it. That could be an oil pan to block bolt and it could be the main leak. The oil could be leaking on the inside between the engine and trans and hitting that horizontal bolt. Please let us know what you find out.
