Nice cars other than x-fire
Easiest way to start a Volkswgen beetle.
Might be a bit different with that big radial bolted on the back . You would have to hand prop it , lol . Had to do that on a 170 one time . Scary as heck. Although I doubt you could spin that one by hand.......
shades of Mad Max
For sure. If it was close behind me I don't think I'd brake test it , lol.
The image shows the Dragon Wolfen Car (also known as the Wolfen Dragon Car), a custom-built metal art vehicle created in Russia.
Stan Winston School of design
• Design: Hand-crafted with an aggressive, post-apocalyptic animal/dragon/wolf aesthetic featuring metallic fangs, scales, and heavy off-road tires.
• Origin: Built in Russia and often compared to vehicles from the Mad Max franchise.
Hmmm.... Totally different prop than the previous picture. Looks like the same VW... Same tires, trim and fender cutt-offs. No license plate on this one. And a prop that won't hit the ground....
I believe the prop isn't attached in the video. You can see the prop shaft sticking out . Real machine though . At least no one would tailgate you , lol.
I suspect
I suspect the shroud you see in the video is for cooling the engine as radial engines are air cooled . Probably blades inside that shroud .
I suspect
Yes. Has blades on the outside. If you stop the vid a second before the end, you can see the blades. And yes. The pitch angle of the blades appears to be there for cooling.
