Very nice car and welcome to the forum.
Are you running the car with a front license plate?
Cheers
Cheers
It attaches directly to three of the front bolts that hold the splitter on. It's a perfect fit, flush and invisible, actually provides some strength and stability to the splitter. Just remove the existing bolts and bolt the bracket in place. Voila! I am extremely finicky and this is the perfect item for mounting your plate. The ability to remove the plate with a simple pull on a pin is a plus and the mounting plate cannot be seen when the plate is removed. Excellent product.If you get a chance to have your car up on a lift can you send me a pic of underneath where it connects to the car, would like to see where the main part attaches on this car before I decide on maybe getting this item. Thanks
Go to stonsho.com . Lots of pics, videos. Lifetime guarantee. I normally don't endorse any products, but this is the real deal. I didn't want to put a GM bracket on because of the way it looks and it interferes with airflow. No such issue with the Sto N Sho. It exceeded my expectations.PS to my reply above. It was a direct fit for my ZR1. No drilling required. About 10 minutes to install and did not even have to jack the car up. High quality part. Good luck.
stonsho.com
I just removed SA from the center so bracket would fit. You could put the SA back on once installed. I probably won't have the car up on a lift for several months, but you can call me in Montana at 406-799-4286 to discuss.So u cut up the SA center piece to put the bracket on?
Please post up a pic again when u have the car on a lift still would like to see the bracket attachment when SA is there.
PS...the attaching plate is only about 1/16" thick, so you could reglue the Scrape Armor onto it once it's in place. I didn't think that it was necessary, but it could be done easily.
