Eventually if you keep that car you will want to treat all of the rubber with the dielectric grease to keep the rubber supple and seal around the glass properly.Thank you.
Yes but easy cleaning.Got mine HTC this Friday. Has anyone found grease on on the top of the rear window?View attachment 123439
yes, my 23 had it, quite a bit....Easy to clean off. Most likely from excess from the window regulator that has grease on it from the supplier...Got mine HTC this Friday. Has anyone found grease on on the top of the rear window?View attachment 123439
