GM opens official investigation into C8 Corvette transmission leaks
I smell a recall coming, 🤣. I remembered that my C8 had a check engine light came on but it disappeared a couple of hours later and it had less than 1000 km. Since then, no check engine light.
Check engine light can be related to any of a million things. Often times on some cars it is related to the emissions system. Unless they read the code that turned the light on they will not know he cause of the alert. Mine came on at 7,000 kms. They reset it. It came on again 100 kms later. Turned out in my case it was trans related. Tried the flush with no luck. Then had to replace the valve body and all has been good for the next 3,000 kms.
