Thanks. You just reminded me where I heard that . In that video. You would think that they knew what they were talking about. More so than some guru on Reddit , lol.This a lot of confusion about this, largely created by Josh Holder, Corvette Chief Engineer. At the Bash in 2024, Holder said that while driving on the highway they've programmed the TCM to do essentially the same thing as the HSF. But not exactly the same thing, because cycling the valves would, I believe, cause the DCT to shift gears. He said that if you're a DIYer, you can change the filter without doing the HSF. Harlan Charles and Tadge Jeuchter were with him, and neither disagreed.
BUT, the service manual specifies the HSF as step 1 of the external filter replacement. It doesn't say "unless you don't have access to the software," or "unless you're a do it yourselfer." If you have a DCT issue under warranty, and didn't do the HSF, it won't be Josh Holder who decides if it's covered by the warranty.
At the same time, it appears not all dealers follow the procedure and perform the HSF. So, is it OK to skip the HSF? Your call.
