And it begins....Body off
wondering if you know a good company in saskatoon to sandblast the frame, I started but its just to hard for me to see what i'm doing without my glasses. also what do most of them charge
I was lucky and I could get it done at work. It is pretty expensive but Commercial Sandblast and Paint could do it. I guess we could do it here to depending on timing. I think our rates are around $315 per hour (includes blast media which is a coal slag). It would take about 1-1/2 to 2 hour if you are doing all the control arms and misc. parts with the frame. I would think under an hour for just the frame. We could get an actual quote though.
T
Well it has been far to long. I have the vette back into the "work" bay of the shop. Plan to get the pedals finished up and firewall work done tonight. I though I should share why I haven't been working on the vette, beside life in general.
First we added onto our house staring in 2014 finishing last summer.
House before.jpg House Digging Hole.jpg HOUSE ICF.jpg HOUSE FRAMING.jpg House Interior.jpg House Finished.jpg
Also I decided to fix up my old Ranger (after breaking the window by accident!) at the end of 2015. The white is how it was. Red is now. It was in worse shape than the pictures show too:
2016-01-03 09.11.28.jpg 2016-01-02 19.47.52.jpg 20160101_160945.jpg 20160101_161047.jpg
Plus many other little projects. Anyway...I am hoping to get a lot done on the vette before summer so stay posted!
T
Well got the clutch all figured out after putting many hours into trying to get the Camaro pedal set up to fit and scraping that idea. I had to guess at how much stroke the pedal should have. I based it off my Ranger clutch and adjusted for feel. (educated guess) Feels good while pretending to drive, and I did quite a bit of that. Piggy backed the clutch off the brake pedal shaft just like the stock set up, however I made my own pedal arm and reused the pads (for both brake and clutch) off the camaro pedals. The tricky part was fitting all the Camaro switches to work with the Camaro wiring harness I am planning to reuse. All aligning to the master cylinder (again from the Camaro) running through the stock clutch rod hole in the firewall with a really odd looking adapter to fit it. All in all I am happy with the results. I don't have a finished pic yet due to wanting to put in new bushings when I put it back together. Oh and a couple nice coats of black paint on the parts.
20160304_225244.jpg20160304_225302.jpg 20160304_225356.jpg 20160304_234918.jpg 20160305_003051.jpg 20160305_004940.jpg
So got some time in the shop on Friday night. Tackled a "big" job. I took the firewall off the birdcage. Big shout out to corvette-restoration.com as I used his experience and documented process to help, especially with rivet locations! I guess it was big because I was nervous about what I was going to find underneath. Luckily, and not usual for this car, it was way better than expected. The lower corners of the birdcage at the windsheild are not rusted through and the pillars look fine. The bottom of the pillars will need some work but I can handle that. Also the top corners of the windsheild mount are rusted but I already knew that. All in all the birdcage looks very usable and I have decided to not go any further in pulling off body panels. I also pulled out the seats and the floor boards look better than I thought they were too! A few holes and cracks but definitely fixable. Here is some pics:
And after a touch of wire wheeling:
Hope I can keep finding time. Getting closer and closer to making it look like a car instead of the opposite!
T
Good question. As you've probably already thought about, I guess it depends on the thickness of the por15, (which you already know) and if the por15 sticks as well or better than the bonding agent to the metal and if the bonding agent sticks to the por15, but as you stated, you could scratch up the surface.
If you do the por15, let me know and I can send you some money as I have to por15 the bottoms of the doors on my truck, if you're alright with me borrowing a door bottom's worth of por15.
