Hi. Hope someone has experience with this problem.
1989 C4 coupe with auto.
Problem: misfire at idle and under load. Intermittently clears for a few seconds then back to misfire.
Replaced:
Any ideas for a fix? I'm baffled.
Replaced:
- New injectors (from Fuel Injection Connection, stock size)
- " plugs
- " wires
- " fuel filter
- " distributor cap, rotor and module
- " intake manifold gasket (leaking china wall)
- Timing set at 6 degrees BTDC
- Fuel pressure check (40 #) Gauge bled down to zero after 10 min. Clamped return line, slowed pressure loss, clamped both return and feed lines, still bled down slowly. Might be that I used locking pliers to clamp off lines and pressure bypassing these.
- Checked fuel pressure at WOT during test drive and all was good. Pressure stayed at between 38 and 44 pounds.
- Injectors firing (noid light check)
- Cleaned MAF
- Vacuum test with propane
- Compression test (all cylinders good and close together readings)
