Could you send me pics?I had this issue as well. At the time the recommended fix was to drop the plastic panel under the steering column, disconnect then reconnect the pig-tail three or four times to wipe corrosion from the connection. Push back together and secure with a tiny zip-tie.
This is really simple and required the removal of the under-dash light from the plastic panel to make access that much better. Takes about 20 minutes for a newbee. I'll see if I can find a picture of the pig-tail on the web for you. If I recall it was basically the first pig-tail you will see and also the easiest one to grab.
Before you spend a penny try this really easy fix and see if it works for you.
My problem was solved and never returned.
Edit: My "Service Active Handling" warning popped up only during very low speed maneuvers like parking and slow but tight corners. I think it came on once when I first started my car ....
Dick
Well problem solved it infact was the brake switch! corrected at dealership for $89 plus tax! I can't believe that switch kept my car from starting , shifting out of park, brake lights staying on and active handling light coming on during hard turns. That's one evil gremlin....
Hope this helps someone else
Cam
