Nik
Administrator
Beta
Jan 11, 2009
4,562
3,305
As of about 30 mins ago I've introduced a couple of key behind the scenes features.
1. Similar threads listing - at the bottom of every thread you will now start seeing additional results for threads similar to the thread you're reading. The search is performed in two parts by thread title minus common words. In case the thread does not answer your question you can click straight through to a similar thread. Note, if you don't see anything it means no similar threads were found.
2. Better search - introducing elastic search. No change except you should start getting better search results. Will take a while to index every word properly but expect improvements in the next short while.
