It sho do .Stupid question. Does the PDR automatically turn off once the car is turned off even if you have it set to automatically record?
you are right, it was!!Stupid question. Does the PDR automatically turn off once the car is turned off even if you have it set to automatically record?
Is the world flat ?No such thing as a stupid question!
Not sure the question is stupid, but any answer other than "No" sure is.Is the world flat ?![]()
Not a stupid question…all depends on context.Is the world flat ?![]()
Was not I that suggested it was a stupid question. On the contrary, I was the first one to answer him. Thank you very much sir. Follow the bouncing ball.Not a stupid question…all depends on context.
As for the OP, he is new here, help him out answer the question move.on.dot.com
To some. Ever heard of the "flat earth society"?Is the world flat ?![]()
Charter member here !To some. Ever heard of the "flat earth society"?
It does, your recording is saved and it starts recording again the moment the car is re-started.Stupid question. Does the PDR automatically turn off once the car is turned off even if you have it set to automatically record?
Yes indeed you did answer right away and much appreciated. I was referring to your semi rhetorical stupid question “ …is the world flat?” which you posted after Murray’s comment, in some contexts it is not a stupid question - ya I can follow the ball my LIEGE.Was not I that suggested it was a stupid question. On the contrary, I was the first one to answer him. Thank you very much sir. Follow the bouncing ball.
Correct, There is a setting for that.it also stops recording once your card is full, unless there is a setting to let it overwrite over older recordings.
There is .it also stops recording once your card is full, unless there is a setting to let it overwrite over older recordings.
I was referring to the second part of your post. My intention was not to offend you.Yes indeed you did answer right away and much appreciated. I was referring to your semi rhetorical stupid question “ …is the world flat?” which you posted after Murray’s comment, in some contexts it is not a stupid question - ya I can follow the ball my LIEGE.
