Need new rims .
2015 Z06
Has anyone replaced their rims with a set of Forged wheels ?
Im now on my 4th broken rim and i think its time to go with something stronger . Im just looking / asking if anyone knows a place or shop where you can get them .
Trying online for me has proven a waste of time .
I,ve even tried sending e mails to Corvette depot and Northern Corvette with out any replies .
Looking for 20x12 rears and 19x10 fronts as its for my 2015 Z06 .
Thanks in advance for any help .
Kaz .
Kaz .
Found this using Perplexity AI.......
You’re looking at essentially the factory Z06/Z07 sizing, so 19x10 front and 20x12 rear forged options are plentiful and proven for a 2015 C7 Z06.Wheel options in 19x10 / 20x12A few examples that are built specifically for the C7 Z06 (correct 5x120.65 bolt pattern and hub bore, and designed around the OEM 19x10 / 20x12 spec) include: ALT Forged (Gem Motorsports – ALT5 / ALT10 series)Sizes: 19x10 front, 20x12 rear with offsets in the ~+30 mm front / +50 mm rear range that match widebody C7 Z06/GS/ZR1 fitment.Construction: Monoblock forged 6061‑T6, hub‑centric, accepts OEM caps and TPMS.Made‑to‑order with multiple finishes (gloss black, brushed, carbon flash, etc.) and ~5–6 week lead times. Splux SC‑04 custom forged 2‑pieceExplicit fitment listing for 2015–2019 C7 Z06 (including Z07): OEM size option 19x10 front / 20x12 rear.5x120.65 PCD, 70.3 mm hub bore, forged, DOT‑verified, and compatible with OEM TPMS/caps/lugs and OEM tire sizes. Other forged/custom brands ' RVRN and similar custom houses offer 2‑piece forged sets in 19x10 / 20x12 with “OEM spec” for C7 Z06, generally letting you choose offsets, finishes, and lip/barrel style. Fitment notes for your 2015 Z06 Offsets: Aim around +28–30 mm front and +48–50 mm rear to stay in the safe, “flush but not dumb” zone on a stock‑height or mildly lowered Z06; many C7‑specific wheels are pre‑spec’d there. Bolt pattern / bore: 5x120.65 and 70.3 mm hub‑centric are correct for C7; most Corvette‑specific forged options list these explicitly. Tires that commonly pair with this setup: 285/30R19 front and 335/25R20 rear are the usual match for 19x10 / 20x12 on a C7 Z06 and are sold as matched packages for those wheel sizes.
