Interac or iDebit: How Easy is It to Fund Your Pin-Up Account from Canada?
Status
Not open for further replies.
niktester2
Test Title
A review of Pin-Up Casino deposit methods: comparing Interac and iDebit. We tell you which is more convenient for Canadian players and why. Deposit and Withdrawal Limits
Using Interac and iDebit to Fund Your Pin-Up Casino Account​
AD_4nXf03a9uuinr0lxFF9yPrCC7-gNRJA1gAJyECfFerQZGktfhCbichcWE3ENEzAYYcLYWitMAFCGdojmhR8_wNgZ6BZGkxi18X_f0B6y9o2k15siog6Nv2hDIDZpeAhdw7UXn2LA5AA
If you live in Canada and play at online casinos, you're probably already familiar with Interac, a payment system that is supported by almost all banks in the country. But not everyone has heard of iDebit, although this platform is no less convenient for betting. In this article we tell you how exactly both methods work at pin up casino, how they differ and what you should really consider before transferring money.
Interac: Fast, Clear and Commission-Free​
One of the main advantages of Interac is that it's essentially part of Canada's banking infrastructure. There's no need to register separate accounts or download apps. If you have a Canadian account with TD, RBC, CIBC, Scotiabank or another major bank - chances are Interac is already available. And, importantly - Pin-Up allows you to make a deposit through this very instrument.
In practice, it looks like this: log into your Pin Up casino Canada account, go to the "Cashier" section, select Interac e-Transfer or Interac Debit. Then either enter your card details (if using debit) or go through a secure gateway to your online bank and confirm the transfer. Funds are credited fairly quickly - most often within a couple of minutes, although in some cases it can take up to 24 hours, especially if it's your first payment.
What is particularly convenient is that all transactions are made in Canadian dollars. This means no unnecessary conversion fees. The minimum deposit through Interac is $10 and the maximum is up to $10000 for a single transfer. Pin-Up doesn't charge a fee, although it's worth checking to see if your bank charges a fee - some institutions may charge a nominal fee for Interac transfers, especially if you have a basic package.
iDebit: A Worthy Alternative When Interac Isn't Available​
If for some reason Interac is unstable at your bank, or you just want an alternative, iDebit is worth considering. It too is a payment system, also Canadian-centric, and works through a secure connection to your bank account. The difference is that for the first payment via iDebit you will need to create an account on the service's website - but the process is simple and takes 2-3 minutes.
Afterwards, everything is similar: go to "Cashier" on the Pin Up Canada website, select iDebit, log in to your account and confirm the payment. The money is credited instantly or within a few hours. As with Interac, all transactions are in Canadian dollars and the casino does not deduct any commissions. According to user reviews, most banks do not charge additional fees when working with iDebit, but it is still better to clarify this in advance, especially if you use a credit card instead of a debit card.
By the way, many players note that iDebit is convenient to use in cases when you need to make a small deposit, for example, $20-30, just to test a new game. This method is also suitable for those who play irregularly, but want to have a quick way to deposit funds at hand.
How to Deposit: Step-by-Step, Without Unnecessary Movements​
AD_4nXcbJSmgyibdDLiFqXCSKtPc-WSyS66h82HAWvM2xl9CUaoX26kF-HF3rQiWVljx8jaMz322aCE5edehertfCzj9qlMOByrXJoUsLqL-2L6ncEiXSFqKtuOtQnH5DzhMPmBsCXEhXg
From a technical point of view, both methods are quite simple. Below is a visual comparison of what it looks like in practice.
Via Interac:
Via iDebit:
  • You log into your account on the Pin-Up site;
  • Select Interac from the list of methods;
  • Specify the amount, then the system redirects you to online banking;
  • Confirm the transfer and you're done.
  • Choose a method;
  • Log in to your iDebit account;
  • Select the linked bank;
  • Confirm the payment;
  • The money is credited to your balance almost immediately
In both cases, it's important to make sure you use the same method through which you plan to withdraw the money. Pin Up Canada, like most licensed casinos, requires the withdrawal method to match the deposit method. This is to prevent fraud and "bypassing" verification.
It's also worth going through the KYC (identity verification) process after your first deposit. To do this, you will need to upload a photo ID and possibly proof of address - for example, a utility bill. If you don't do this in advance, your withdrawal may be delayed.
What is More Convenient and Where You Should Be More Careful​
Specifics are always important when dealing with payments, so I'll highlight here a few key pros and cons that are important to keep in mind. Not for the beauty of the list, but to make it immediately clear whether it's worth getting involved:
Advantages of payment systems:
  • CAD support - you don't lose money on conversion;
  • Fast crediting - from a few minutes to a couple of hours;
  • Both methods work with most Canadian banks;
  • Pin Up takes no commission on deposits.
What to watch out for:
  • Not all banks support Interac Online, sometimes you'll have to use e-Transfer;
  • iDebit requires separate registration, although the process is simple;
  • For withdrawal you need to pass verification, prepare documents in advance;
  • If you use a credit card, check the terms and conditions of commissions with the bank.
General Impressions and Recommendations​
If we talk humanly, and not in the style of advertising banners, then both methods really work. They are not the fastest or the most favourable options when compared to cryptocurrencies, for example. But they are definitely the most convenient and predictable for most Canadian players.
Interac is for those who value simplicity and don't want to register anything extra. iDebit is for those who want an alternative or work with banks that don't support direct Interac transfers. In both cases, you won't encounter any technical difficulties. The Pin Up casino interface is arranged in a logical manner, with instructions appearing on the screen as needed.
If you are just starting to play or just testing the platform, I recommend you to deposit $20-50 via Interac and get verified immediately after deposit. This will save you time in the future, especially if you want to withdraw your winnings.
Status
