Helpful hints
Little red 2020 C8
Just thought I'd start a thread with helpful hints.
I watched a Facebook short video showing how WD40 will dissolve Spray foam.
You always use a little spray foam and then leave the can sit and it clogs up and you have to dispose of it.
Well, no longer. When done take off the nozzle, spray WD40 in it and the can and voila, it's clean and ready to use again.
It will even clean it if you have left it clogged for a time.
Sore neck , shoulder, etc ? Fill a sock with uncooked rice and microwave for three or four minutes and voila, a mouldable heating pad.
And add a little maple syrup for a high carb snack when finished.
You did in the microwave. OK, so they are a little chewy.
You could always just take your teeth out….. :rolleyes: it really does work well though. You can make a larger one with a small pillow case . Just buy the cheapest mega bag of rice in the store and you are set.
