Is this card worth getting to save money on C8 purchase and discounts on accessories
www.gmcard.ca
This card you mention has a $79 annual fee. There is another GM card same as above except only 5% on the first $5000 annually and 2% thereafter. I think I will be able to accumulator $1k GM earnings to put toward my C8.Sure....
5% GM Earnings on the first $10,000 in net purchases annually
2% GM Earnings on net purchases annually thereafter Redemption
How To Redeem - GM Card
www.gmcard.ca
www.gmcard.ca
Not true of the Scotia Card (unless there’s recent fine print changes) ... i had the junky old TD GM Card - very restrictive like max $500 earnings per year and max $3500 redemption and limited models. It has gone away.GM will limit your redemption amount depending on the vehicle you are buying.
My goal when I started with the Scotia Card was to get a free car. But i saw an ad for my Corvette in the newspaper one day ... and as you can see, things really got out of hand after that. Yes, i would have had $12k for the Sierra ...I stand corrected. Good to know. I only had the old card, and couldn't imagine they would go back to an unlimited redemption (If you hadn't bought the Vettes, you'd get nearly $12k off your Sierra).
The old TD version GM Visa had all the restrictions.Has anyone used their rewards from this card now that people are actually taking delivery of their C8's?
Apparently... "some restrictions apply". There is an "exclusion list" somewhere.
. Maybe someone who actually used it against their C8 purchase will post up here?You can redeem the $'s on any GM vehicle.I have a preferred card I like to use as well but I have a few hundred dollars I'd like to use up on this Scotia GM Card.
After digging through their web site, I found a link to their "see the exclusion list" and there is nothing on it. I would assume that would mean there are no vehicles excluded from using your rewards for this card. I would feel better if my salesman could enlighten me, but he says he doesn't know either. Maybe someone who actually used it against their C8 purchase will post up here?
... or eventually, I guess I'll find out.
I think the "no exception" pop up says it all.I have a preferred card I like to use as well but I have a few hundred dollars I'd like to use up on this Scotia GM Card.
