Happy to announce the official launch of our C8 Air Defectors, customized for maximum airflow for your C8. StingRay, E-Ray & Z06 ! The ONLY air vent/solution with enhanced airflow and integrated debris/bug deflection.
Available here: DynamicDucts™ - C8 Street Edition
Keep your C8 (Stingray, E-Ray & Z06) running cooler with custom Engineered DynamicDucts™ - an OEM-inspired air-deflection system built for the Stingray, E-Ray, and Z06. Using proven engineering, our DynamicDucts mount seamlessly in minutes to channel cool ambient air into the engine bay, reducing heat soak from headers, cats, and exhaust components.
✔ GM OEM Replacement/Enhancement: GM OEM Compatible Upgrade: Precision-engineered replacement for OEM Part Numbers 85580654 & 85580653, delivering superior fit, strength, and significantly improved performance improvement.
✔ Scoop-Style Air Routing: Innovative deflector design channels with enhanced high-volume airflow to critical hot spots, ensuring even cooling distribution without disrupting aerodynamics.
✔ Honeycomb Grill Guard: added protection against ingesting bugs or road debris
✔ Durable PETG-CF Construction: Engineered from high-grade, corrosion-resistant materials for OEM reliability, blending perfectly with your Corvette's undercarriage.
✔ Bolt-On Simplicity: Installs in under 15 minutes using existing skid plate hardware. No drilling, or modifications required. Straight bolt on using existing skidplate bolts. Perfect for DIY enthusiasts or weekend warriors.
✔ Universal C8 Compatibility: Tailored for all 2020+ C8 models, including Stingray, E-Ray & Z06 variants.
As Seen On:
HorsePower Obsessed:
Brandon's Garage:
GM OEM parts unavailable in Canada !!
DynamicDucts™ Shipping Next Business Day.
As Seen On:
Brandon's Garage:
