Before you ask, I did do a search.
I didn't see anything (assuming I used keywords that would find it!).
I just picked up a '94 convertible and I'm having an odd issue with the driver side door lock. With the door open I can use any of the locking methods (key, power lock, manual slide) and it will lock/unlock no problem. But, if I close the door and lock it (by any method) or I hit the lock and close the door it will not unlock. I noriced that when using the key it doesn't travel as much on the unlock side with the door closed (or open with the latch closed). Looking at the mechanism it appears there is a tab that is not being engaged when this happens. Tough to see in there, even with the door panel off.
Has anyone had a similar issue? If so, is this repairable or am I looking at a new lock/latch mechanism? I'm getting tired of having to either crawl in from the passenger side or using a screwdriver to hit the tab in the mech through the door sill!
Kirb
Kirb
