Cruise Control
1980 Coupe
AB
I've done a few searches but still not found the answer I seek. I am dropping in a new motor in my 1980 and I am most likely not going to put the cruise control diaphram back on the carb linkage. I want to clean the engine bay up and minimize what goes back in for a cleaner look. I probably only ever use the cruise control once anyways. not sure if it even still works. my question is, if I don't plan on using the system can I take the transducer and all of the related vacuum lines out of the system? Does the wiring harness that goes from the transducer to the plug on the firewall only control Cruise control? If I unplugged that and capped the socket on the firewall will that affect any of the other electrical systems?
