Coils packs, Wires, and Plugs
Stock coils are more than adequate for the majority of applications. I'm making in excess of 1K HP and they are holding up fine. MSD wires are known to be good. I would highly recommend running socks on them if you have headers, to keep the heat away. Plugs will be very dependant on what power levels you are running (stock vs modified), and if you are running any type of forced induction or power adder.
What have y’all done? Which is the best?
Little more info on your car might help IAWO. And welcome to the forum.
Thank you sir
You'll not likely have to replace the coils for any reason, performance or otherwise, I run GMPP Performance 8 mm wires with NGK BR7 C spark plugs btw....
