Help Any one have experience replacing / installing the metal door panel tops to new door panels ??
1962 FI 2003 conv
Any one have experience replacing / installing metal door panel tops to new door panels ?
originals stapled but main concern is making sure they are in correct position before attaching ???
Thanks Ken
Yup! It wasn't easy aligning the metal plates up to the door panel. We used pop rivets (stainless Mandrel) and made sure they did not interfere with the fit. Put the metal on the door then attached the door panel and marked where the edge of the panel hit the metal both ways, took it apart popped then tried again. Took a few try"s. The fit was okay after glueing on the vinyl door skin. Watch out for stripped out screw holes for the door panel mounting screws. We made repair plates for key points but next time will use riv certs to fill worn out holes. I might have mentioned before to use stainless steel screws and washers to save a headache later.
Sounds like you are getting close to completion.
Bob & Gina
