Alberta Lithuim Battery
So I reached out to them and got a reply for the model SKU: 00059. This is the closes dimension and has the power posts in the same orientation as our H6.
They said they use them in Diesel Trucks, in hybrid and EV.
This AL 00059 unit is slightly shorter than ouf H6 by almost 1.5". Length is 9.5" vs 10.98"/H6. Width is virtually the same 6.69" vs 6.89". Height is the same. Weight in at 14.5 lbs.
H6/AGM spec: 760 CCA 45 lbs.
AL Spec: 850 CCA. 14.5 lbs
Antigravity H6 spec: 1040 -1450 CCA. 19.5 Lbs
At less than half the price of the Premium Antigravity H6 but without their fancy reserve start which the AL doesn't have. However it does have the app for you to keep track the condition of your battery. The only thing is to see how well it sits into our battery tray. Some modifications may be require? Will have examine the holding down assy of the oem to to see if this would work. I am confidence that I can make something and adapt to the oem bracket to make it work. Will see. Put on the mod list.
Saw a toaster that you could connect to with it's app......... ;)
